berny822
Nov 09, 2017Aspirant
MR1100 do not charge
This is my third replacement from AT&T. When you try to charge the hotspot it won’t charge. Using the original cable you net to unplug and plug again again and see if you have luck with it start to c...
TeeJay74
Nov 09, 2017Virtuoso
What is the current device temperature and battery temperature ? If temp is high, and it does not charge then use external fan to cool it down and see if it starts to charge when temperature goes down. I am hopeful this may work for you.
berny822
Nov 10, 2017Aspirant
Operating at normal temp, but tried to discard and the problem persist
