b0rdga
Mar 23, 2018Aspirant
MR1100 does not broadcast wifi
hi guys
my hawk suddenly stoping broadcasting wifi i tried every singel idea come in any technation mind
- restarted
-reseted
- power off
- playing around with setting
but didnt work
after all i end up with i cant add any apn even with changing sim
any idea
Thanks all for your advaices
I finaly fix it
just manual update it to 10.25.01.01
and im sorry for the bad spilling
you can download it from here
- b0rdgaAspirant
BTW ITS UNLOCKED
Telstra
- MicWLuminary
Does the dashboard or the wifi profiles shows that wifi is enabled and the "broadcast wifi name ssid" has a tick next to it on both the 2.4 and 5 ghz under settings>setup>wireless page?
- JasonNNETGEAR Employee Retired
Hi b0rdga,
Have you tried removing and reseating the SIM card in the device?
Please let me know if this helps. :]
- Jason N
- b0rdgaAspirantYes its look good without any problems in dashboard
And i had changed the SIM with more than 3 SIMs different company and also no APN & WIFI
