slphelan
Feb 02, 2020Tutor
MR1100 EUS FIRMWARE PROBLEM
I used the below guide to update my router it was successful only one problem. I did not have a sim in the unit when I installed the firmware upgrade now every time I put a sim in the router I does a boot loop for 4-5 times then shuts down. I cannot boot the router or turn it on without removing the battery power. If no sim I can log in 192.1681.1 and see or make changes just cannot boot with sim.
Currently my router shows Firmware upgrade: NTG9X50C_10250101
APN changed for ATT to Telstrainternet
is there any newer firmware or solutions available that I can fix this issue?
I used the following info below to upgrade
Firmware LINK:
Re: MR1100 Firmware Update
:MR1100 Firmware Update
Download the newest generic firmware from the Netgear support site for your country (the routers country).
Download FDT.exe version 4.6.2.0. (You’ll have to Google)
Download AC78x Netgear drivers version 4.3.00
Download Putty
Put everything in the same folder
Install drivers
Connect MR1100 directly to computer with USB cable
Open putty, telnet into MR1100 ip address with port 5510
Run AT!BOOTHOLD
Close Putty
Open cmd, change directory prompt to where you downloaded everything to. Type ”FDT.exe insertfilename.secc.spk” and hit enter. Do not touch anything. If the command prompt tells you after “resetting device” that the upgrade failed, ignore it and let the MR1100 do its thing. It may look like it’s frozen, but it should finish and boot by itself after about 10 minutes.
Download Putty
Install drivers
Run AT!BOOTHOLD
Close Putty
- slphelanTutorResolved by installing the correct firmware. No speeding right along. Thanks
- jmatsonAspirant
I am having trouble finding the drivers to download
- Blanca_ONETGEAR Employee Retired
Hi jmatson
MR1100-100EUS firmware download link:
https://kb.netgear.com/000061731/MR1100-100EUS-Firmware-Version-12-06-11-00
Blanca
Community Team
- JohnPengNETGEAR Expert
Firmware LINK:
Re: MR1100 Firmware Update:MR1100 Firmware Update
Download Putty
Install drivers
Run AT!BOOTHOLD
Close Putty
Open cmd, change directory prompt to where you downloaded everything to. Type ”FDT.exe insertfilename.secc.spk” and hit enter. Do not touch anything. If the command prompt tells you after “resetting device” that the upgrade failed, ignore it and let the MR1100 do its thing. It may look like it’s frozen, but it should finish and boot by itself after about 10 minutes.These are not the correct steps for end users to use. You are risking to brick your device and void your warranty.
Thanks
- slphelanTutor
The links in the guide worked but I had to go to netgear and download the software for my country. The software listed in the guide is not for USA. It was for Austraila if I remember correctlu
