DieselTrucker87
Feb 01, 2020Follower
MR1100 Fails To turn on
When you plug in device with battery or not the NetGear screen lights up and turns off a few times with the orange led light in the corner and fails to boot up fully. Pushing the reset button for more then 5 seconds dont change anything nor does the sim card in or out. I think this unit needs replaced?
1 Reply
- JohnPengNETGEAR Expert
Yes. Most likely, the device need to be replaced.
Thanks
