noname1233's avatar
noname1233
Follower
Oct 06, 2018
MR1100 help
I just got a new MR1100, and I'm having some trouble with it.
First real problem is that it won't play video files from the sd card. The file is a webm and it plays the first 3 seconds and then "buffers" not playing any more video.
Next, I noticed all connections to the router itself are not using secure standards web portal is HTTP not HTTPS, and the webDAV is using DAV not DAVS, is there any way to enable secure communications?
My next problem is I can't figure out any options to make the router itself a VPN client to route all my traffic through a VPN. I can see an option to enable VPN passthrough, but I want the router itself to be the vpn client.
Lastly, I'm curious if it's possible to enable VLANs on the single ethernet port to allow for a wired "data offloading" wan connection AND a LAN connection for wired clients.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi noname1233
    Welcome to NETGEAR Community!
    May I request for the following information:
    - Play videos from the SD card, does the issue present with this specific file type? What about videos on a different file type?
    - Who is you ISP?
    - How is the router setup?
    - What is the firmware version?
    Blanca
    Community Team
  • Blanca_O's avatar
    Blanca_O
    Hi noname1233,
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
    Blanca
    Community Team
