merson
Aug 25, 2018Follower
MR1100 Nighthawk - Have to change settings to manual whenever I turn on
Hi
I have a netgear MR1100-100EUS Nighthawk LTE Mobile Hotspot that worked perfectly for first month, but now every time it is turned on it flashes orange and doesn't connect until i go to app on phone where it says data is disconnected and i have to change the connection settings to manual - this is a real pain and time consuming - how can i stop it as it worked perfectly for first month.
1 Reply
You will get better results (and might be able to find even some related posts) when using the specific Mobile Routers, Hotspots & Modems subcommunity.
