jaj2465's avatar
jaj2465
MR1100 Nighthawk LTE Mobile Hotspot Router
I have my Alro Camera paired with my MR1100 but when I go onto Arlo's webpage to discover the MR100 it stated device cannot be found.  Camera, router and computer are on same 2.4 wifi.  Some post say it doesn't work anymore, some say option is coming, Netgear's literature say it will work.  No luck getting through to tech support.  Please advise, thank you.
  • ArodiD's avatar
    ArodiD
    NETGEAR Expert
    Hi jaj2465,
    The Arlo base station feature is not actually enabled on the MR1100 as yet.  There will be a firmware update around Feb timeframe for Telstra SKU device which will have the feature enabled.  Which model of Arlo camera are you trying to pair?
    ArodiD
    • jaj2465's avatar
      jaj2465
      I have a VMC4030-100NAS.  How can I get set up to receive the notification that the needed firmware has been released?
      Thank You
