LSwerd
Dec 27, 2017Follower
MR1100 Nighthawk LTE Mobile Hotspot Router
I just purchased a Netgear LTE Mobile Hotspot to access the internet. I own an ORBI wifi system. Can I use the Orbi and Hotspot together (the hotspot doesn't cover my whole house but the Orbi does.) Thanks
1 Reply
- mdgm-ntgrNETGEAR Employee Retired
You can.
What I'd probably do is get a 2.4A charger (this is needed for running with battery removed) for the Hotspot, remove the battery and connect the Hotspot via ethernet to the Orbi. In fact I just got a 2.4A charger today myself.
You may want to avoid double NAT e.g. by putting the Orbi into AP (Access Point) mode.
