P303
Feb 17, 2018Aspirant
MR1100 password wont work with ipad
Hi. My ipad refuses my password as incorrect even though the MR1100 is working perfectly with my Mac with the same password?
michaelkenward
Feb 18, 2018Guru - Experienced User
This tells us that the problem is the iPad. The MR1100 does not "work with" the wifi clients. It is the other way round. unless you have set up the MR1100 to block wifi devices.
The first trick in such situations is to tell the wifi client to forget that it even encountered the wifi source, the SSID, and to recreate the connection from scratch.
