P303
Feb 17, 2018Aspirant
MR1100 password wont work with ipad
Hi. My ipad refuses my password as incorrect even though the MR1100 is working perfectly with my Mac with the same password?
P303
Feb 25, 2018Aspirant
MR1100 has now stopped working with my MacBook!. I haven’t changed anything in the Mac,diagnostics state everything is working correctly.
JasonN
Feb 28, 2018NETGEAR Employee Retired
Hi P303,
I wanted to check if your MR1100's firmware is up to date with the current firmware version. If so, then did you do a factory reset after the firmware update?
Please let me know if that fixed the issue. :]
- Jason N
