ianobrien43's avatar
ianobrien43
Follower
Aug 26, 2019
MR1100 powered only by 12VDC
I have an ATT MR1100 mobile LTE router. I need to be able to power the unit without the battery via the USBC cable connected to a 12VDC USB port in my houseboat. My USB 12VDC port says it's rated for 2.1A (but I kinda doubt the cheapo Amazon port). When I plug the unit in it cycles power over and over. I have to keep the battery installed for it to stay on all the time. I have read though that this is bad for the battery. I have tested the unit in my office with the battery removed and it stays on all the time with no power cycleing. So I'm convinced it is the USB supply or USB port on my boat. I'm more convinced it's the USB port.
Can someone give me some advice on what components to use in a 12VDC RV/houseboat application to keep it powered constantly without the battery?
1 Reply
  • You probably can't take that 12VDC onto M1 USB-C port, need another charger supporting QC, 2.0/3.0, and you can then have a change cable plugged inot M1's USB-C port, make sure you buy a good quality of the charge cable (USB to Type-C, or Type-C to Type-C, depends on your charger) as M1's power design is very sensitive, improper cable would cause stability problem.
