TyroneSuperNut's avatar
Mar 15, 2020
Mr1100 questions
Hello. I am interested in the MR1100. I have a few questions.
*What kind of speeds can i expect in one of the worst states for service coverage? My sprint network gets around 15 mbps download.
*Is the NAT type open? Moderate? Strict? Can you change it?
*How long will the battery last if 5 devices are connected?
*Do i have to worry about over charging the device?
*Can you do casual games on it? Basically decent ping?
Thanks in advance.
1 Reply
  • *What kind of speeds can i expect in one of the worst states for service coverage? My sprint network gets around 15 mbps download.
    Speeds will be very close to mobile speeds unless you provider supports carrier aggregation
    You can open ports manually
    I get all day battery 20h or so with low power and nothing connected to the ports at the back
    No I leave mine connected 24/7
    Depends on carrier, if you gaming jitter is the worst problem not ping
    My ping in around 50ms but my jitter is 10, meaning 1 pack can take 50 ms the next could be 40ms and the one after could be about 60
    Try tethering from your phone first
