dw1009
Nov 09, 2017Follower
MR1100 Strict NAT
I recently purchased the MR1100 Nighthawk LTE mobile hotspot from ATT and while I love the router for its speed and connection (rural user without high speed options) I am having a bit of a time get...
Sean101
Jan 26, 2018Aspirant
Hi dw1009,
Most cellular connections has a strict NAT type and most inbound packets are closed or filtered. If you are with AT&T you can request for a static IP or set a DynDNS on you R6300 which I believe will handle inbound and outbound packets instead of the ISP(Please correct me if I'm wrong). Kindly check the link below to enable DynDNS on your device:
