abofayez's avatar
abofayez
MR1100 The operating system can not be updated
welcome everybody
I finally got a router. The router works well and the back of the operating system is version 10.05.04. After searching for the update I had an update of 83 Mb. I downloaded the program directly. After the download you click Update. The router rebooted only and did not update the operating system. Try it through mobile. I dreamed through my computer using Safari, Chrome and Opera without any benefit. I tried to update the system through Windows 10 in all browsers and the update was not installed. I then tried to update the system on five other Windows machines. All this and the system is not installed. Where is the problem ? Is there any help?
    • UK-based's avatar
      UK-based
      Luminary
      Where did you find the update firmware file? I thought that there were no firmware updates files available on the Netgear site for the MR1100 - it normally auto-updates itself, presumably accessing the firmware on a private Netgear server or your carrier's server.
      • abofayez's avatar
        abofayez
        Yeah . The update appears on the Settings \Administration\Firmware Update. But After downloading, the router is not updated. Only restarts and this message appears in red: Error: Unabled to update firmware.
