Teewee4134's avatar
Sep 29, 2017
MR1100
On the LCD screen of the Nighthawk M1
Show 4G but am surprised its not showing 4G+
Has anyone ever seen 4G+ on their MR1100?
  •  Hi Teewee4134
    If you are using the Telstra MR1100 then you will never see 4G+ RAT icon as this was never implemented on this SKU.  The only way you can determine your device is doing carrier aggregation is if you are seeing over 150Mbps on the downlink.
    Kind Regards,
    ArodiD
  • Please apply some network traffic (speedtest or file download) and check the RAT symbol again.
    • Teewee4134's avatar
      Teewee4134
      Guide
      I have apply network traffic but no changes still just 4G
      What is RAT?
      • TeeJay74's avatar
        TeeJay74
        Virtuoso
        RAT means Radio Access Technology, Symbols like 4G, 4G+ are RAT symbols indicating network technology used.. It may be possible that basestation could have some configuration issue which prevents CA activation, license issue etc. Maybe you have to check this from your local cell operator if you think it is necessary.
  • ArodiD's avatar
    ArodiD
    NETGEAR Expert
     Hi Teewee4134
    Kind Regards,
    ArodiD
