allfreedom's avatar
allfreedom
Follower
Sep 16, 2019
mr1100
hi,got a problem
my m1 keeps giving bad internet
switch form 4g to 4g+ to h+
please help
tryed a new simcard but that those not help
is it the apn?
  • Hi allfreedom
    Welcome to NETGEAR Community!
    Please check the signal quality using the Diagnostics screen found under Settings > Nighthawk M1 Status > Diagnostics section using values below as reference:
    RSRP – The average power received from a single Reference signal, and Its typical range is around -44dbm (good) to -140dbm(bad).
    RSRQ – Indicates quality of the received signal, and its range is typically -19.5dB(bad) to -3dB (good).
    If the reception/signal continues to be poor then we suggest moving to location with clear view of the sky or consider purchasing/using external antenna.
    Blanca
    Community Team
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi allfreedom
    Blanca
    Community Team
