klbcolt's avatar
klbcolt
MR1100ATT factory reset does not show the wifi password on the display
I bought a used MR1100ATT to replace one that stopped working recently.  After plugging it in, it starts up wifi and I then try to connect to "ATT-WIFI-kPGT".  However, the display screen on the MR11...
  • klbcolt's avatar
    Dec 16, 2021
    Never mind.  I removed the battery and the label underneath has the password.  Duh!
