duckthis1's avatar
duckthis1
Initiate
May 17, 2019
MR1100EUS – Nighthawk M1 Mobile
Hello,The original OEM battery recently started to only charge to 1/4 capacity.I replacaed the battery(aftermarket) 2 days ago and the display only shows that it is charged to 1/2 capacity.I have tried to charge with the unit on and with it shut down.While on the digital battery graph readout goes up and down like it is charging normally. Any help would be greatly apreciated.Thank You
  • Thanks for the reply.I actually found out that unplugging the cat cable allowed the battery to be charged fully. Even the battery that I thought was bad charged up fully. I'm not sure if that is mentioned somewhere and I am not sure why the cat cable plugged in does not allow a battery to be charged,but it worked.Thanks
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi duckthis1
    Welcome to NETGEAR Community!
    Please do the following:
    1. Unplug the Nighthawk Mobile Hotspot Router.
    2. Remove the battery.
    3. Wait for 30-60 seconds, and reinsert the battery.
    4. Hold the Power Button to restart the device.
    5. Use the original power adapter (originally shipped with your device) to recharge your Nighthawk Mobile Hotspot Router.
    May we please know the current firmware version?
    Blanca
    Community Team
    • duckthis1's avatar
      duckthis1
      Initiate
    • Blanca_O's avatar
      Blanca_O
      Hi duckthis1
      Glad to hear that you got it working.
      Blanca
      Community Team
