supajo's avatar
supajo
Follower
Jun 08, 2020
MR1100EUS - Firmware
Hi, i have heard that for the MR1100EUS is a new firmware version 12.06.12.00 available.
Trying to use the update check from the webinterface nothing happens.
When will the download on the supportpage be available?
Greetings Patrick
1 Reply
  • Yes, mine updated itself 1 week ago from 12.06.11.00 to 12.06.12.00, I could not prevent it.
    PRI goes from 10.03 to 11.01
    GUI goes from 4.01.80.00 to 4.01.81.00
    Firmware date is 2020/04/26
    It updates automatically even if no battery is plugged.
    No information at all on what is changed/fixed.
