H24423
Apr 24, 2023Aspirant
MR5200-100EUS wont connect to network
Hi,
My Netgear MR5200-100EUS _04.02.196.00 will not connect to the network. Stuck in searching for carrier.
I have tested with SIM cards from two different providers. SIM cards work fine on mobiles and Netgear Aircard 810S.
Details of my Nighthawk M5
Hardware version 1.2
Firmware version NTGX55_12.04.17.00
Firmware built date 2023/03/01
Modem version MPSS.HI.2.0c3.5-00010-SDXX55_CPEALL_PACK-10403198.3
Device has been factory reset a coupe of times, but no luck.
It has worked fine in the past, though the firmware has never really been stable. I suspect the issue is with the firmware. Is there a repository to upgrade or down grade firmware somewhere? I also have a ticket opened with Netgear support, where Netgear engineer responded they will definitely get back. However after nearly 2 months, still waiting.
Can someone please help solve this issue???
Thanks
- JohnPengNETGEAR Expert
Please capture a model.json file and send PM to me.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backThanks
- H24423Aspirant
Hi John,
Thanks for reaching out. Requested file sent per PM.
- brent-m5Aspirant
Hi H24423 I am having the same issue with my M5 - did you manage to find out what the cause of your problem is?
My post is at https://community.netgear.com/t5/Cell-Service-Mobile-Hotspot/Netgear-M5-MR5200-100EUS-issues-in-Australia/td-p/2312516
Thanks đ
