Xop0's avatar
Xop0
Star
Oct 26, 2022
MR5200 manually update the firmware
How I can manually update the firmware if there is no files on support website?
https://www.netgear.com/support/product/mr5200.aspx#download
My m5 is definitely broken, but the problem may be due to an update failure. The device can only work when the screen is off, otherwise it endlessly reboots after 10 seconds.
Unfortunately, resetting to factory settings does not roll back the firmware. And I can't find other versions of the software other than the one installed NTGX55_12.04.12.00
And there is no support answer in last simular tread https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/MR5200-100EUS-firmware-NTGX55-12-04-12-00/td-p/2236173
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Your device is on the latest release. You can try do a factory reset if you suspected the device was not upgraded properly.
    I have replied to you on your model.json file. I will try to help you to resolve the issue.
    Thanks
    John
