Tedro's avatar
Tedro
MR5200 no longer works with T-Mobile
Hello,
Starting in September, mr5200 no longer works with T-Mobile..  I can connect to their tower with excellent signal strength, however. all clients connect but with no internet.  I have tried multiple sim cards including prepaid T-Mobile, with same problem.  Purchased support contract from Netgear and they say hardware is ok, must be T-Mobile.  After 3 months of tmo support, they tell me something on their network must have changed that is preventing the mr5200 from working, but cant tell me what that might be.  Tell me i have exhausted all the support options at T-Mobile.  Has anyione else experienced this?  Any ideas on how to proceed?  I did purchase an ATT prepaid sim and it did work.  So, thinking hardware is ok.
  • It seems like you've thoroughly explored troubleshooting with T-Mobile and Netgear. Since the device works with an AT&T prepaid SIM, it suggests the hardware is functional.
    Consider reaching out to T-Mobile again, providing this information, and inquire about any specific network changes affecting the MR5200.
    • Tedro's avatar
      Tedro
      Thanks for the reply. I did contact tmobile support and netgear support when the att sim card worked.  TMo said I exhausted their support offerings and all I could do was open another ticket, which I did.  Same conclusion - no help. I asked netgear if they had any reports similar to my experience and they said, no. I am sure someone at tmobile knows what's going on, I just don't know of a way to contact them.
      Any suggestions on how to escalate at tmobile? Any help would be greatly appreciated.
      Thank you.
      • Tedro's avatar
        Tedro
        I think t-mobile no longer supports the bands the MR5200 needs to operate. I purchased a MR6550 and it works with my tmobile account. Does this sound plausible? I would have thought netgear support would have received numerous calls if this is the case. I wish I could have found someone that could definitively state what changed and when.
