sdzfg's avatar
sdzfg
MR6110 does not create a 5g wifi band
Hi there my MR6110 has stopped creating a 5g wifi band.
please advise
  • plemans's avatar
    how do you know its not creating a 5ghz band?
    Do you have them combined into 1 band?
    Have you done a scan using a channel scanner?
    • sdzfg's avatar
      sdzfg
      Yes I used Net Analyser and Airport utilty scanner. ItI wish it was combined but alass no.
      • plemans's avatar
        did you check to see if it got turned off? on the screen go to wifi>options>wifi signal.
        then check if its on/off
