nevdowling's avatar
nevdowling
MR6110 unable to connect to Telstra
Bought the MR6110 from JB Hi-Fi in Tweed City (BTW great service there) but after just 3 days I've experienced "Unable to join the network [SSID]" on multiple devices (iPhone, iPad, sometime after being connected for 30+ minutes.
Disconnecting and forgetting the SSID then reconnecting seems to work, but it's a pain and I didn't have this problem with the ZTE MU5120 from the same location using the same Telstra 5G network.
I only changed routers because JB Hi-Fi offered a better deal than I had with Telstra on the ZTE device.  I contacted Netgear Support but the chat session offered only that I should contact Telstra, which anyone in Australia knows will take up most of the day and generally achieve nothing.
I have been able to connect to the admin page and checked that the firmware is NTGX65_12.01.41.00.  Netgear chat suggested changing the Channel & DNS.  From the www. routerlogin. com/ interface Status/diagnostics menu I see that the channel is 3148 but there's really no way to change that, the only thing that's configurable is 5G, 2.4Ghz or both.  I use 5G only.
If this continues I still have the ZTE MU5120 and I'm wondering if I can swap the sim into that?
1 Reply
  • It sounds like your MR6110 is having Wi-Fi stability issues, even though it's using the same Telstra 5G network that worked fine with your ZTE MU5120. Since you’ve already updated the firmware and are using only the 5GHz band, the issue might be related to compatibility or signal interference. The error “Unable to join the network” suggests the router may be dropping connections or devices are struggling to maintain a stable link.
