dhd2026
Mar 11, 2026Aspirant
MR6110 WiFi Schedule fails to work
Hi all, I have a Nighthawk M6 MR6110-1TLAUS Mobile router that I am having an issue with. It is running on the latest firmware, NTGX65_12.01.41.00 Every time I try to setup this device to hav...
Mar 14, 2026Guru - Experienced User
Might try a reset because I tried the schedule on mine and it worked fine.
Also something else to try, if I remember correctly, it struggled if the time was set at 00:00. So if you're using that for a time, go for 00:01.
