mikewuk
Feb 16, 2026Follower
MR6110 Won't boot anymore
My router worked fine for many months but then froze and won't boot past the 'Netgear' screen. Power cycling and switching between mains and battery doesn't help. The reset button has no effect...
Feb 19, 2026Guru - Experienced User
If its not even a year old, try getting it replaced through support before you try forcing a firmware to it.
