axalam9
Dec 28, 2023Aspirant
MR6150 - Cannot connect to 5G only bands
I recently upgraded the firmware on my Netgear M6 MR6150 and for some reason I have lost the ability to connect to only "5G" bands under CELLULAR > BAND REGION. I used to have this option before. Und...
- Jan 16, 2024
JT240Z wrote:
Not sure that SA is supported yet in any M6 versions. Maybe John can chime in to clarify.
Yes. We disabled 5G SA support in the latest release with the following considerations.
1. Both AT&T and Verizon don't support 5G SA. So the device was not certified by them with 5G SA
2. T-Mobile supports 5G SA, but based on our testing, the device performance in SA mode is poorer than in NSA mode since in NSA mode, the device can use the LTE connections for data transferring.
If you do need 5G SA support to test on provide network, please reach out to me directly. We can discuss how this can be supported.
Thanks
TeeJay74
Dec 29, 2023Virtuoso
Hi,
In my understanding "5G only" means using 5G SA(standalone).
Br,TeeJay74
axalam9
Dec 29, 2023Aspirant
Yes that is correct. I used to have that option before and now it has disappeared. I just want to use 5G bands.
- JT240ZDec 29, 2023Luminary
- JohnPengJan 16, 2024NETGEAR Expert
Thanks
- rensahoboMar 24, 2024Aspirant
I had the same problem, my device couldn't connect to 5G
MR6110-111AUS
NTGX65_10.01.49.00 (2022/09/09)
