rolelael
Jun 29, 2025Follower
MR6150 - Nighthawk M6 - MCC/MNC issue
I'm using the nighthawk for a while with a Belgium sim card ( Digi Belgium ) . Custom apn added.
When I was abroad ( Holland ) last week it didn't work. But ok roaming was not enabled so enabled it , fine.
When I came back to Belgium, no luck. On the display 'searching' ... Even after rebooting.. no luck
Did a reset started over, no luck
When I put the sim card in a mobile phone all is ok .
When I put another sim in the router , that's also fine
Then I looked at the diagnostics, and I'm surprised. The MNC is not correct for my simcard. It's also detected as another provider ( BASE ) .. Contacted support and they told me to check on a mobile phone and try changing MNC. When I put the sim in a phone, the MCC/MNC was correct.... so no need to change.... When I put it back in the router, wrong MNC. ANd there is NO Way to change it on the M6 ..
Now I'm complete stuck. Support of mobile provider, tells me there is nothing wrong with their sim
Any idea? how can I tackle this on the M6 ?
Thanks
- sera93Aspirant
tellpopeyes comIt sounds like you've done a thorough job of troubleshooting, and it's definitely a perplexing situation. The fact that your Digi Belgium SIM works in a phone but not in the Nighthawk M6, and another SIM works in the M6,
- daivdMAspirant
Hi,
You should reach back to support and send them a model.json of your M6 w/ the SIM not working.
