kimsh
Jun 13, 2026Aspirant
MR6150 4G+5G Mode make Loop and Reboot
Hello, I am using a Netgear MR6150. After updating to firmware version NTGX65_12.01.74.00, the device entered a reboot loop. At first I thought the firmware update had completely broken the d...
kimsh
Jul 04, 2026Aspirant
I experienced the same issue.
As a workaround, I downgraded the firmware and have been using an older version without any problems.
You may want to try firmware version 12.01.31.00. On my MR6150, that version works normally in **4G+5G mode** and does not cause the reboot loop.
