kimsh
Jun 13, 2026Aspirant
MR6150 4G+5G Mode make Loop and Reboot
Hello, I am using a Netgear MR6150. After updating to firmware version NTGX65_12.01.74.00, the device entered a reboot loop. At first I thought the firmware update had completely broken the d...
adamfoulkes
Jul 09, 2026Aspirant
Running the MR6150 in 4G+5G mode causing a reboot loop usually points to a firmware bug, unstable network compatibility, or signal issues. Try updating the firmware, resetting the router, testing with another SIM, or locking it to 4G or 5G separately to identify the root cause.
