Grapsen
Feb 19, 2024Initiate
MR6150 APN error 512 and intermittenly not finding sim
Hey, I have the Nighthawk MR6150 and it worked pretty flawlessly for a couple of months. But recently now it started getting the APN 512 error maybe once a day, but now it wont really stay on longer ...
Blanca_O
Feb 20, 2024NETGEAR Employee Retired
Hi Grapsen
Please provide the following information:
- Internet Service Provider
- Firmware version
Kindly insert the SIM card to a different device (mobile phone) and check if it will work.
Blanca
Community Team
- GrapsenFeb 20, 2024Initiate
Im using Talkmore, and Talkmore is using Telenor's network. The firmware is: NTGX65_12.01.48.00. The sim card works in a mobile phone.
- Blanca_OFeb 22, 2024NETGEAR Employee Retired
Hi Grapsen
Kindly contact your Internet provider and check what is the correct APN and if you are using the correct data plan.
Blanca
Community Team- felickzJul 15, 2024InitiateSame issue, same behavior.
Worked fine one day, woke up next day and now can't find sim. Restarted 4 times and now it found it but only lasted for an hour. Error 512 in the UI.
Two other sims I have from same provider seem to work fine.
