someoneelse2222's avatar
Apr 13, 2026
MR6450 crashes when SIM card is used
Hi,
I have an issue with my MR6450, it works fine when there is no sim card inserted but as soon as it boots with one in it crashes?
Firmware version: NTGX6_12_74.00
  • I experienced the same issue.
    As a workaround, I downgraded the firmware and have been using an older version without any problems.
    You may want to try firmware version **12.01.31.00**. On my MR6150, that version works normally in **4G+5G mode** and does not cause the reboot loop.
  • @ someoneelse2222,
    Question is your mobile router a cellular region branded version, for example AT&T network or something else?
