someoneelse2222
Apr 13, 2026Aspirant
MR6450 crashes when SIM card is used
Hi,
I have an issue with my MR6450, it works fine when there is no sim card inserted but as soon as it boots with one in it crashes?
Firmware version: NTGX6_12_74.00
- FortraLuminary
@ someoneelse2222,
Question is your mobile router a cellular region branded version, for example AT&T network or something else?
- someoneelse2222Aspirant
Hi,
Where did you download this from?
- kimshAspirant
I experienced the same issue.
As a workaround, I downgraded the firmware and have been using an older version without any problems.
You may want to try firmware version **12.01.31.00**. On my MR6150, that version works normally in **4G+5G mode** and does not cause the reboot loop.
