ConsciousAssets
May 01, 2026Initiate
MR6500 no longer connecting without battery
I purchased a MR6500 from Amazon. I set it up and it worked great with the battery removed and antennae installed. I had to do a factory reset because I couldn't remember my admin details and needed to login into the attwifimanager site. After the reset I tried to setup the Plugged In: Max performance with battery removed. It says it needs to reboot to enable this mode. I let it reboot and took the battery out, but the device doesn't connect any more. I tried taking battery out before and after the reboot and neither will work anymore. The device just turns black and will not come on unless I reinstall the battery. Is there something I am missing.
- brucejane6Aspirant
That does sound like the reset may have changed the power settings, so hopefully someone can confirm whether the battery-free mode needs to be enabled again. 666D.
Page 57 of the User Manual describes connecting to the MR6500 web interface:
- ConsciousAssetsInitiate
Now that I have reset the device to get the admin password reset, the attwifimanager will not accept the default wifi password under battery and will not let me enter anything in username. Help anyone?
