boofrmb
Jan 08, 2025Aspirant
MR6500 pro interfering with digital tv
Hi All.
Just seeing if anyone else is having an issue or knows how I can eliminate the problem.
The MR6500 pro is about 15m away from the tv, but continues to wash the digital picture out, notice its worth on mpeg4. Once the unit is turned off, tv all good, put the old M2 back in service, still no issues with the tv, so not sure where to go.
Not sure if it should be returned or not.
Thank in advance
Robert
Thank in advance
Robert
Is the tv running over a hardwired connection or wireless?
What happens if you hardwire it in?
Is it connected to the 2.4ghz or the 5ghz currently?
- boofrmbAspirantThis is interfering with the free to air TV channels,the unit is not connected to the TV, and is wifi around the house for only phones, ipads etc.
Not using it to stream any TV channels.- plemansGuru - Experienced User
they use different wavelengths. did you try a different antenna on the tv?
