Mgross102
Jul 19, 2025Tutor
MR6500 shutting off multiple times a day
Saw some previous discussions about the same issue. Running, no battery mode, Device is shutting down multiple times in a day's use. Previous discussions all said to update the firmware device is sho...
Jul 21, 2025Guru - Experienced User
When it doesn't have a battery, they're more susceptible to sketchy power supplies. Have you tried a different supply and cable?
Mgross102
Jul 21, 2025Tutor
Been using the factory cord and power block. Took another suggestion and run it without the back on and it hasn't done it?
