totorotenten
Jul 24, 2024Tutor
MR6550-100APS & MR6550-100PAS / which ones is the best for 5G bands in Viet Nam (APAC)?
Hello everyone,
As mentioned in the title, I really need help about which Netgear models is the best to use for 5G in Viet Nam (a country in Asia Pacific - APAC) ? Mr6550-100PAS or Mr6550-100APS
According to this knowledge base link as below
https://kb.netgear.com/000065647/Which-countries-can-my-NETGEAR-M6-or-M6-Pro-roam-in
The model Mr6550-100Pas will be the best fit … but it’s for American area … To be honest I’m really so confused
And based on the specs of Mr6550-100Aps, it should be the one … totally different with the KB above
So I really need your advice , any recommendations or suggestions are highly appreciated
Thanks so much for taking the time to read
For your information: both models I mentioned above are unlocked versions
- rcpaxLuminary
Hi. I know this is an older post. I am replying for the sake of others that might have the same question. Compatibility is really more of an issue of what carrier you will be using it with. I am not familiar with Vietnam Mobile operators and I am not familiar with their supported bands. It is vital you know or provide these information so I can better look into what would be better suited for your need.
- W1lliamVirtuoso
MR6550-100APS has better fit, NR5G service in Vietnam is on n3/n7/n38/n41/n78/n257
That’s right. I can confirm that after tried two different model MR6550-100PAS and MR6550-100APS already
