Hoffstrong9
Sep 14, 2025Follower
MR7400 Bugs
MR7400 Bug: WiFi standby issue with apostrophe in SSID + Cellular tab only shows info in Cellular-only mode I’m using a Netgear Nighthawk MR7400 (M7 Pro) and have run into two reproducible issues...
hrwthompson
Sep 23, 2026Aspirant
I have the same issue and removing the apostrophe fixes it.
Logging into the it via a PC allows you to use the apostrophe. Creating the SSID using the touchscreen on the nighthawk does not allow you to use an apostrophe as there is a limited keyboard.
Model: MR7450
NTGX75_10.04.43.01
Software version: MR7450-100EUS_01.15
