Hoffstrong9
Sep 14, 2025Follower
MR7400 Bugs
MR7400 Bug: WiFi standby issue with apostrophe in SSID + Cellular tab only shows info in Cellular-only mode I’m using a Netgear Nighthawk MR7400 (M7 Pro) and have run into two reproducible issues...
harryjosh
Sep 24, 2026Aspirant
Bugs on the MR7400 can be particularly frustrating when they affect connectivity or normal device management. It would be helpful to include the firmware version, exact symptoms, and whether the problems started after an update, since those details could help narrow down the cause.
