carl-chapman
Sep 23, 2025Tutor
MR7500 M7 Blocking VPN clients with MacOS Tahoe 26
Hi, I run a MacBookPro M2 through a MR7500 Nighthawk M7 (on the Telstra network). I use OpenVPN client software to connect to a remote business network, and it has been running fine for years...
Sep 26, 2025Guru - Experienced User
If its an issue on all your devices after an upgrade, I'd check with apple. They might have changed something with how their VPN's operate. I don't have a MAC (sorry, not sorry) so I can't test it with you.
Could be something with apple relay or random mac/ip causing issues.
