ericofmelnibone
Nov 30, 2018Aspirant
N300 Travel Router PR2000 - Need to take apart and fix loose power connection, How?
So... I have used this router for 5 years and has "mostly" worked well enough travelling. However, I made a mistake and packed it with the usb cable plugged in so... the power connection inside the router is now loose and needs to be fixed.
There is one screw in the back, which I have removed... but now what? Not sure how to get into the router to fix the loose power connection. Anyone have any ideas on this?
Apparently, there is a concerted effort by the industry to not provide this type of router any longer, so I need to repair this one since no other types of routers like this exist. That work reliably and with any kind of speed (Hootoo an example).
j
1 Reply
- ericofmelniboneAspirant
So, I cut the "tape" on the back with the name and password and it was able to get it separated, started anyway, however it binds where the antenna is connected. Can the antenna be removed and how? It seems like the two halves of the router will separate easily if the antenna can be removed.
