Dragonboy1
Apr 13, 2023Aspirant
neatgear m6 over heating
dose anyone having over heating issues with the m6 this my second one its hitting 62c with a fan on it and it very slow speed and just not very good
I've got the MR6110 and no issues with overheating.
Are you running it in performance mode?
Are you using it with the power plugged into it and the battery in it? or battery removed?
- Dragonboy1Aspirantyeah plig in no battery
Do you have both wifi bands enabled or only one?
