Eric_R
Jan 07, 2016Aspirant
Need help for Aircard 762s and his Netgear Hub
Hello, I just buy an Aircard 762s and a Netgear Hub. The Aircard 762S alone is working fine. I Have 3G, 4G, WIFI, etc. I can surf on internet with all my connected devices. BUT When I...
Eric_R
Jan 08, 2016Aspirant
Well, working !
Just need to change the Hub LAN ip range.
Original Sierra IP Hub is by default on the same range as the Netgear Aircard 762S:
192.168.1.x.
Just changed the hub range with 192.168.169.x (or what U want on a private range).
in Power user -> advanced view -> Internet Settings -> LAN -> IP setup
And the DHCP Hub with the same range 192.168.169.x
in Power user -> advanced view -> Internet Settings -> LAN -> DHCP
After, Static routes are automaticly good.
All is working like a charm.
Just no bip when I dock the Aircard on the hub. But I don't really care :-)
'hope that will help other customers
Will you plan new firmwares for these devices or they are too old ?
And last question : when the Aircard stays on the hub is it better to remove the battery to preserve it ? (yes tested, the Aircard can work docked on the hub without battery)
DarrenM
Jan 11, 2016Sr. NETGEAR Moderator
Hello Eric_R
Yea removing the battery will preserve it rather than over charging the battery.
DarrenM
