richardx73
Apr 01, 2016Aspirant
Need port forwarding help on 6100D
I have a 6100D gateway with a public IP address (Sprint). I've successfully set port forwarding for four ports on one internal IP address (192.168.1.20). I've tried to forward two additional por...
richardx73
Jun 08, 2016Aspirant
I have not figured it out, BUT I have found a work-around that achieves my objective.
First of all, the Netgear support was no help at all. Three calls and three stupid answers: try a different browser, try Chrome browser, try a different computer (!), reset the box. I never talked to anyone who knew anything! Always sandbagged by someone reading from a script.
My 6100D eventually took a second IP address after reseting the box. I needed three, but never got that. My workaround was to swap my 2-port serial port server for a 4-port model, thus eliminating my need for the third IP address. In my case that works to my satisfaction (asidde from the expense of the new server).
I firmly believe there is a SW bug in the 6100D, but no one was willing to listen.
BTW: I started with Sprint support (my carrier), but that was a bigger joke.
Maybe Chrome will help you. Try a box reset. Sneak up on it and it might work for you. Sorry.
randomjak
Jun 15, 2016Aspirant
Thanks for the reply. Netgear and Sprint tech help was very tech-less and no help- like you said, scripted responses. They say my unit should be replaced, but, like you, I think it is a software issue since several people have reported this problem. I did a settings reset, but it did nothing. I will try a facory reset next, and hopefully I can get a second IP to hold. Thanks
- TimewingAug 14, 2016Aspirant
finally found a smart person online that found the Netgear GUI: http://[your IP address for your 6100d]/adv_index.asp. This is the GUI you need to use for port forwarding- and many other functions the Sprint GUI doesn't have or doesn't work... After one replacement RMA with the same lame result, countless faux "techs" ridiculous non support (Netgear and Sprint), this actually works. I put in my second IP address for port forwarding and it took without a hitch. Here is the smart guy's full article link: http://s.co.tt/2014/08/26/netgear-lg-6100d-sprint-lte-gateway-advanced-configuration/
cheers!
-Tim
