jon_brisbin
Jun 28, 2018Aspirant
Need specific antenna recommendation for MR1100 AT&T version
 I'm trying to make this MR1100 work in my home with the very spotty AT&T signal strength we usually get. We're not out in the middle of nowhere but for some reason, I have a really hard time getting ...
plus-sk
Jun 28, 2018Apprentice
Hi Jon,
With the MR1100 you may use Netgear MIMO Antenna with two TS-9 Connectors.
Netgear Website: https://www.netgear.com/service-providers/products/mobile/mobile-hotspots/mimo-antenna.aspx
Amazon: https://www.amazon.com/Netgear-6000450-MIMO-Antenna-Connectors/dp/B00DN3J03O
Yes, it's directional antenna, but fully compatible with modern Netgear mobile hotspots.
