willformayor
Sep 08, 2017Follower
Need to unlock telnet on lb1120 LTE modem
I get great service with band 4 and would like to lock it in. it switches between 4 and 12. band 12 is horrible
superjet
Dec 01, 2017Star
It is complete and total crap the way support with these LTE modems is handled. You cant output a log file or download the firmware/software yourself. I've been trying for 40 days to get my lb2120 to download an update to hopefully fix the complete trash broken bridge connection that is well documented on these forums. 10-20mbps connection to the internet through the router on the lan port, cant update software. Registered product with netgear, only 90 days support without going through their phone support. Last time years ago I had an issue with one of netgears products it involved a NDA and engineering firmware that didnt even fix the problem.
None of the fixes on the internet for unlocking telnet have worked for me either.
Since you cant get a changelog for a new software release who knows if the update even addresses any of the issues you're having.
Like netgear even cares
