aquar1us
Sep 09, 2016Aspirant
Netgear 760s mobile hotspot change route ip address help
I have 760s Bigpond mobile hotspot 4g i change route ip address 10.0.0.138 to 192.168.137.162 in web homepage,
after device restart i can't open 10.0.0.138 or http://bigpond.4g and 192.168.137.162, i actived internet connection i can't wifi sharing to another device & thatering via usb to computer.
i try to factory reset to hold wps button & power button 5 second after device restart nothing happen to change still same with that problem.
before i change route ip address i backup config to export.cfg file
please help for solution this problem?,
maybe tool import config file to transfer export.cfg? because i can't open web homepage.
sorry for my bad english, thanks.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello aquar1us
after the factory reset the ip should be 192.168.1.1 try that to log into the modem.
DarrenM
