mariano86
Jul 12, 2016Follower
netgear 790s strange and big problems
My netgear 790s this morning presented some big problems.
Soft touch buttons don't work anymore, and name of connection and password dissapeared from main screen
I've tried a factory reset, but without results
What you suggest to do?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello mariano86
I would contact your provider that you purchased the device from check if it is still under warranty.
DarrenM
