kartika
Jan 06, 2015Tutor
netgear ac327u
Hi,
I am facing issue with newly purchased netgear AC327U. The connection becomes inoperative after some idle time. Like if I am reading a page, after some time if I click there is not download activity. The connection shows connected but no download activity happens.
I have windows 7 and vodafone connection
Thanks
Kartika
- kartikaTutorThe support staff told me to disable the option switch off device when idle in the power management tab.
For sometime the issue was resolved
But I am facing the same issue again. - kartikaTutorThe broadband genie shows connected and full bars and is still unable to load the pages.This device is really bad. :mad:
- tekbirdAspirant
I have a 3G USB dongle marked as Netgear AC327U.
When I plug in the device, in device manager, it's shown as a mass storage device.
And when the supplied application is run, it enables 3G modem interface of the device and device manager shows up COM ports for them. And it is listed in the Control Pane > Phone and modems.
What I would like to do is enable the modem interface without using the accompanying application.
I also tried with another brand which also seems to behave the same.
Is there any way the modem can be detected as is even without running their proprietary application?
- DarrenMSr. NETGEAR Moderator
Hello Tekbird
I believe you still have to use the application.
DarrenM
