Retired_Member
Nov 11, 2016NETGEAR AC810-100EUS- DNS timeout
Greeting!
I bought a Netgear Hungary AC 810 wifi router.
The problem is that it does not work as Dell Inspiron N5110 laptop. One of the DNS servers did not respond.
Wifi: (Intel Centrino Wireless N1130)
Default Server: netgear.aircard
Address: 192.168.1.1
> 127.0.0.1
*** Netgear.aircard can not find 127.0.0.1: Non-existent domain
UPnP -> There is no connection (USB cable)
Thank you very much?
- akidoApprenticeMany issues highlighted but deaf ear policy from netgear
- Retired_Member
New firmware is available on the device. Solve these problems?
- Retired_Member
Unfortunately, the problem could not be solved yet. :( Someone knows a solution? Maybe the Netgear AirCard 810S wrong? Sometimes after turning on / restart the purple NETGEAR AirCard after writing a caption 127.0.0.1 connection errors. Sometimes the router's administration interface is not available. The router itself is not less than the internal memory? Incorrect firmware? Or not communicate according to Intel Centrino Wireless N1030 wifi card?
The Windows event log, these are:
To unlock the isatap.aircard name during a timeout it happened after one of the configured DNS servers did not respond.
In resolving the name www.facebook.com timeout after one of the configured DNS servers did not respond.
In case of USB tethering to 10 windows 64 bit. not responding, slow 5-10 minutes before the Internet connection is established. If you have an Internet connection, they can sometimes slow to load pages, or does not load.
Thank you for your help!
